Aller au contenu principal
Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement, Touchpad: étape 1, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement, Touchpad: étape 1, image 2 de 2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 2, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 2, image 2 de 2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 3, image 1 de 1
    • Remove the four 4.6 mm screws with the Phillips #00 screwdriver.
  4. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 4, image 1 de 1
    • Use the spudger to pry underneath the cable and remove the connector.
    • Remove the battery from the case.
  5. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 5, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 5, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
    • Remove the silver bracket.
    • Remove the remaining 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 6, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 6, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 6, image 3 de 3
    • Remove the wire connector from the I/O board.
    • Remove the black and white wires from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 7, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 7, image 2 de 2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 8, image 1 de 1
    • Lift and remove the I/O board from the base of the laptop.
  9. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 9, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver port.
  10. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 10, image 1 de 1
    • Remove the silver port from the motherboard.
  11. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 11, image 1 de 1
    • Remove the red and black speaker wires from the connector on the motherboard.
    • Use the #00 Phillips screwdriver to remove the 4.9 mm screw.
    • Repeat the first two steps for the other speaker.
  12. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 12, image 1 de 1
    • Remove the speakers.
  13. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 13, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 13, image 2 de 2
    • Remove the smaller cable ribbon from the port on the motherboard.
    • Lift the clip on the connector on the motherboard and remove the larger cable ribbon.
  14. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 14, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 14, image 2 de 2
    • Use the #00 Phillips screwdriver to remove the four 4.6 mm screws.
  15. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 15, image 1 de 1
    • Lift and remove the motherboard from the base of the laptop.
  16. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 16, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 16, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 16, image 3 de 3
    • Use the #00 Phillips screwdriver to remove the two 4.6 mm screws from both display hinges.
    • Lift the display hinges and remove the keyboard from the screen of the laptop.
  17. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 17, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 17, image 2 de 2
    • Use the #00 Phillips screwdriver to remove the three 2.3 mm screws from the trackpad.
  18. Samsung Chromebook 3 XE500C13-K02US Touchpad Replacement: étape 18, image 1 de 1
    • Remove the grey adhesive tape and lift out the trackpad to remove it from the keyboard.
Caden Smith
Membre depuis le 03/28/23
397 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Harley Spring 2023 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2023
IUPUI-HARLEY-S23S3G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 130
