Aller au contenu principal
Samsung Chromebook 3 XE500C13-K02US Track pad Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: étape 1, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: étape 1, image 2 de 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 2, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 3, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 3, image 2 de 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: étape 4, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: étape 4, image 2 de 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 5, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 5, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 5, image 3 de 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 6, image 1 de 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: étape 7, image 1 de 2 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: étape 7, image 2 de 2
    • Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 8, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 8, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 8, image 3 de 3
    • Remove the ribbon cable by lifting it out of the connector.
    • Lift the grey adhesive tape.
  9. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 9, image 1 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 9, image 2 de 3 Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: étape 9, image 3 de 3
    • Lift the track pad from the top.
    • Slide the track pad away from yourself to clear the black plastic edge.
    • Lift the track pad up and out of the laptop.
Mick McCarty
Membre depuis le 03/18/19
980 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 12
Total : 266
