Introduction
This guide explains the steps to replace your Samsung Chromebook 3 battery. You will start by turning your laptop upside down gently to remove the bottom case. Which is where your your battery is located.
Ce dont vous avez besoin
Place the laptop back cover facing up to show the screws.
Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
Presque terminé !
