Aller au contenu principal
Samsung Chromebook 3 XE500C13-K05US LCD Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 2, image 1 de 1
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 3, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 3, image 2 de 2
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 4, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 4, image 2 de 2
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 5, image 1 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 5, image 2 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 5, image 3 de 3
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 6, image 1 de 1
    • Lift the battery out of the case to remove it from the laptop.
  7. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: étape 7, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: étape 7, image 2 de 2
    • Use a spudger to lift the hinge that locks the gold colored display cable in place.
    • Pop the cable out and remove the hinge from the motherboard.
  8. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 8, image 1 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 8, image 2 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 8, image 3 de 3
    • Using the ifixit spudger, raise the adhesive holding the wireless card antenna wires.
    • Raise the black and white antenna wires with the ifixit spudger.
  9. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 9, image 1 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 9, image 2 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 9, image 3 de 3
    • Remove the four 4.6mm screws from the display mounts.
  10. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 10, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 10, image 2 de 2
    • Once the hinge screws have been detached, open the laptop.
    • The bottom of the laptop will divide from the screen once you are able to open it a certain amount.
  11. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 11, image 1 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 11, image 2 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 11, image 3 de 3
    • Using the ifixit opening tool to pry in between the bezel and screen.
    • You will hear some snapping as you open the bezel with the ifixit opening tool.
  12. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 12, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 12, image 2 de 2
  13. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 13, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 13, image 2 de 2
    • Using the spudger, raise the adhesive tap that is holding the display cable.
  14. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 14, image 1 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 14, image 2 de 3 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 14, image 3 de 3
    • Slowly raise the panel up and fold it over to uncover the display cable on the backside of the display.
  15. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 15, image 1 de 2 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 15, image 2 de 2
    • Using the ifixit spudger, raise the hinge that is locking the gold colored display cable in place.
    • Pull the cable away from far from you to slide it out the monitor.
    • Be tender around the display circuit board, it is labeled "Do not touch."
  16. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: étape 16, image 1 de 1
    • Once the display cable has been detached, raise the screen up and out of the case.
Yamaris Acosta
Membre depuis le 02/07/23
557 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 4-4, Gonzalez Spring 2023 Membre de l'équipe Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 177
