Introduction
This guide will show you how to replace the battery for the Samsung Chromebook Plus.
Pièces
Aucune pièce nécessaire.
Remove the 8 PHILIPS#0 screws
  • Remove the 8 PHILIPS#0 screws
Ajouter un commentaire
Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  • Use your PHILIPS#0 and remove the 4 screws
  • Lift battery from bottom side first (marked with red line)
  • Detach battery cable grabbing the side and pulling the cable upward.
  • Insert the battery and push the plug into the socket downward. As of this time there is no replacement battery for this product available on ifixit.
  • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
To reassemble your device, skip steps 1-5. Unfortunately at the time of publishing this repair guide. There is no replacement battery for this device on iFixit.
2 autre(s) ont terminé cette réparation.
Evan Elm
Membre depuis le 31/12/2017
455 Réputation
2 tutoriels rédigés
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
77 membres
47 tutoriels rédigés
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Réponse
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Réponse
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 116
Total : 445
