Introduction
After a period of time, the device might run too hot, this guide will help to clean up or replace the cooling fan for the Samsung Chromebook XE550C22.
Ce dont vous avez besoin
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Locate the cooling fan and the heat sink on the top center of the Chromebook.
Outil utilisé dans cette étape :Tweezers$3.99
Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
Disconnect the fan cable from the motherboard with the angled tweezers.
