Introduction
This guide shall assist you in fixing a jammed disk tray if you followed thoroughly the troubleshooting steps with no positive results.
Ce dont vous avez besoin
Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
As noted by the red circles, locate and remove the screws one at a time
After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
Slowly remove the circuit board/cables/strips from under the black bar. ( under and over)
Replace the motor in question ( usually both are needed to be replaced)
