Aller au contenu principal
Introduction
Replace the battery in your Samsung Droid Charge. Remove the battery before disassembling or reassembling the device.
Outils
Aucun outil spécifié.
Pièces
  1. Open up the back case on the phone from the groove in the bottom of the phone.
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  3. Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
5 autre(s) ont terminé cette réparation.
Luke Gordon
Membre depuis le 26/09/2012
163 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 15-44, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,295
