Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Droid Charge SIM Card Port Replacement
Ce dont vous avez besoin
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: étape 1, image 1 de 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: étape 2, image 1 de 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    Demander à FixBot
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: étape 3, image 1 de 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    Demander à FixBot
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: étape 4, image 1 de 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    Demander à FixBot
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: étape 5, image 1 de 1
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
    Demander à FixBot
  6. Samsung Droid Charge SIM Card Port Replacement: étape 6, image 1 de 1
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
    Demander à FixBot
  7. Samsung Droid Charge SIM Card Port Replacement: étape 7, image 1 de 1
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
    Demander à FixBot
  8. Samsung Droid Charge SIM Card Port Replacement: étape 8, image 1 de 2 Samsung Droid Charge SIM Card Port Replacement: étape 8, image 2 de 2
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
    Demander à FixBot
4 autres ont terminé cette réparation.
Lucas Carter
Membre depuis le 09/27/12
190 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-44, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 membres
18 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 46
Total : 2,839
