Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Epic 4G Micro USB Port Replacement
Ce dont vous avez besoin
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: étape 1, image 1 de 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Epic 4G Micro USB Port Replacement: étape 2, image 1 de 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    Demander à FixBot
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: étape 3, image 1 de 1
    • Remove the battery from the device by pulling the battery edge upwards.
    Demander à FixBot
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: étape 4, image 1 de 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    Demander à FixBot
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: étape 5, image 1 de 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: étape 5, image 2 de 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    Demander à FixBot
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: étape 6, image 1 de 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    Demander à FixBot
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: étape 7, image 1 de 1
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
    Demander à FixBot
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: étape 8, image 1 de 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: étape 8, image 2 de 2
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
    Demander à FixBot
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: étape 9, image 1 de 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: étape 9, image 2 de 2
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    Demander à FixBot
  10. Samsung Epic 4G Micro USB Port Replacement: étape 10, image 1 de 1
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    Demander à FixBot
8 autres ont terminé cette réparation.
Andrew Cunningham
Membre depuis le 10/03/12
273 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 24-25, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 membres
21 tutoriels rédigés
1 commentaire de tutoriel
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 2,845
