Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Rear Case: étape 1, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Rear Case: étape 1, image 2 de 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 2, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 2, image 2 de 2
    • Lift and remove the rear case.
    Demander à FixBot
  3. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, microSD Card: étape 3, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, microSD Card: étape 3, image 2 de 2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
    Demander à FixBot
  4. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 4, image 1 de 1
    • Pull the microSD card away from its slot.
    Demander à FixBot
  5. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Battery: étape 5, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Battery: étape 5, image 2 de 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
    Demander à FixBot
  6. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 6, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 6, image 2 de 2
    • Lift and remove the battery from the midframe.
    Demander à FixBot
  7. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Plastic Midframe: étape 7, image 1 de 1
    • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
    Demander à FixBot
  8. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 8, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 8, image 2 de 2
    • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
    Demander à FixBot
  9. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 9, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 9, image 2 de 2
    • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
    Demander à FixBot
  10. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 10, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 10, image 2 de 2
    • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
    Demander à FixBot
  11. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 11, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 11, image 2 de 2
    • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
    Demander à FixBot
  12. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 12, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 12, image 2 de 2
    • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
    Demander à FixBot
  13. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Connectors: étape 13, image 1 de 1
    • Headphone jack/vibrator assembly cable connector
    • Front-facing camera cable connector
    • Digitizer cable connector
    • Display cable connector
    Demander à FixBot
  14. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Headphone Jack/Vibrator Connector: étape 14, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Headphone Jack/Vibrator Connector: étape 14, image 2 de 2
    • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
    Demander à FixBot
  15. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Assembly: étape 15, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Assembly: étape 15, image 2 de 2
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
    Demander à FixBot
  16. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 16, image 1 de 1
    • Carefully disconnect the digitizer display cable.
    Demander à FixBot
  17. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 17, image 1 de 1
    • Use a spudger to disconnect the display cable connector.
    Demander à FixBot
  18. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 18, image 1 de 1
    • Remove the two 3 mm Phillips #00 screws.
    Demander à FixBot
  19. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 19, image 1 de 3 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 19, image 2 de 3 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 19, image 3 de 3
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
    Demander à FixBot
  20. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Front Facing Camera/Earpiece Speaker Assembly: étape 20, image 1 de 1
    • Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
    Demander à FixBot
  21. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 21, image 1 de 1
    • Remove the front-facing camera bracket from the display assembly.
    Demander à FixBot
  22. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 22, image 1 de 2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: étape 22, image 2 de 2
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly.
    Demander à FixBot
8 autres ont terminé cette réparation.
1 commentaire de tutoriel
This Repar is NOT for the earpiece speaker. It is for the camera only. The earpiece speaker for the i9100 is attached to the vibrator and headphone jack cable.
tylerdeer - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 45
Total : 9,760
