Introduction
Use this guide to replace your front panel assembly.
Ce dont vous avez besoin
Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
Push the plastic opening tool downward to pry the battery up from its housing.
Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
The first insertion point is a divot to the left of the micro-USB port.
The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
Headphone jack/vibrator assembly cable connector
Front-facing camera cable connector
Digitizer cable connector
Display cable connector
Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
Use the flat end of a spudger to disconnect the front-facing camera cable connector.
Make sure the microphone cover stays in its slot on the display assembly.
When you removed the motherboard, the microphone cover may have remained stuck on the microphone. Put it back in its notch in the display assembly to avoid losing it.
Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
Insert the pointed end of a spudger into the gap in the corner of the midframe to free the vibrator from the adhesive.
18 autres ont terminé cette réparation.
2 commentaires de tutoriel
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
