1. Press button on back of phone below camera.
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by sliding off (not shown in picture).
  2. Grasp the battery near the bottom with two fingers.
    • Grasp the battery near the bottom with two fingers.
    • Lift battery up and out gently.
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
    • Using iPod opener tool, unlatch and remove the camera ribbon cable.
    • Using iPod opener tool, unlatch LCD ribbon cable on left side of motherboard.
    • Using iPod opener tool, unlatch and remove the two ribbon cables at the bottom center of motherboard for the keypad and center button.
    • Using iPod opener tool, unlatch and remove the front panel ribbon cable at bottom right of motherboard.
    • Using the iPod opener tool, remove the microphone cable at bottom right of motherboard.
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of motherboard.
    • Carefully lift motherboard off of phone chassis starting on the left side.
    • There is one ribbon cable still attached underneath the motherboard on the right side.
    • Using iPod opener tool, unlatch and remove ribbon cable on back side of motherboard.
    • Remove the motherboard.
2 autre(s) ont terminé cette réparation.
Mark Wyse
Membre depuis le 19/04/2011
59 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-15, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,462
