Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Exhibit II 4G Headphone Jack Replacement
Ce dont vous avez besoin
  1. Samsung Exhibit II 4G Headphone Jack Replacement, Battery: étape 1, image 1 de 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Exhibit II 4G Headphone Jack Replacement: étape 2, image 1 de 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
    Demander à FixBot
  3. Samsung Exhibit II 4G Headphone Jack Replacement, Top Rear Housing Cover: étape 3, image 1 de 1
    • Pry the top cover upward to remove it from the phone.
    Demander à FixBot
  4. Samsung Exhibit II 4G Headphone Jack Replacement: étape 4, image 1 de 1
    • Remove the top cover.
    Demander à FixBot
  5. Samsung Exhibit II 4G Headphone Jack Replacement: étape 5, image 1 de 2 Samsung Exhibit II 4G Headphone Jack Replacement: étape 5, image 2 de 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    Demander à FixBot
  6. Samsung Exhibit II 4G Headphone Jack Replacement: étape 6, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 6, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 6, image 3 de 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    Demander à FixBot
  7. Samsung Exhibit II 4G Headphone Jack Replacement, Midframe: étape 7, image 1 de 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    Demander à FixBot
  8. Samsung Exhibit II 4G Headphone Jack Replacement: étape 8, image 1 de 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    Demander à FixBot
  9. Samsung Exhibit II 4G Headphone Jack Replacement: étape 9, image 1 de 1
    • With plastic opening tool continue prying around the edge of the back assembly.
    Demander à FixBot
  10. Samsung Exhibit II 4G Headphone Jack Replacement: étape 10, image 1 de 1
    • Pull back panel assembly away from main body.
    Demander à FixBot
  11. Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: étape 11, image 1 de 2 Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: étape 11, image 2 de 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
    Demander à FixBot
  12. Samsung Exhibit II 4G Headphone Jack Replacement: étape 12, image 1 de 2 Samsung Exhibit II 4G Headphone Jack Replacement: étape 12, image 2 de 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
    Demander à FixBot
  13. Samsung Exhibit II 4G Headphone Jack Replacement, Rear Facing Camera: étape 13, image 1 de 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
    Demander à FixBot
  14. Samsung Exhibit II 4G Headphone Jack Replacement: étape 14, image 1 de 2 Samsung Exhibit II 4G Headphone Jack Replacement: étape 14, image 2 de 2
    • Remove camera from square housing.
    Demander à FixBot
  15. Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: étape 15, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: étape 15, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: étape 15, image 3 de 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
    Demander à FixBot
  16. Samsung Exhibit II 4G Headphone Jack Replacement: étape 16, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 16, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 16, image 3 de 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
    Demander à FixBot
  17. Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: étape 17, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: étape 17, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: étape 17, image 3 de 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
    Demander à FixBot
  18. Samsung Exhibit II 4G Headphone Jack Replacement: étape 18, image 1 de 2 Samsung Exhibit II 4G Headphone Jack Replacement: étape 18, image 2 de 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
    Demander à FixBot
  19. Samsung Exhibit II 4G Headphone Jack Replacement: étape 19, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 19, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 19, image 3 de 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
    Demander à FixBot
  20. Samsung Exhibit II 4G Headphone Jack Replacement: étape 20, image 1 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 20, image 2 de 3 Samsung Exhibit II 4G Headphone Jack Replacement: étape 20, image 3 de 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
    Demander à FixBot
David R
Membre depuis le 07/20/15
1 152 Réputation
9 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 609
