Aller au contenu principal
Samsung Exhibit II 4G Top Rear Housing Cover Replacement
Ce dont vous avez besoin
  1. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Battery: étape 1, image 1 de 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 2, image 1 de 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Top Rear Housing Cover: étape 3, image 1 de 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 4, image 1 de 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 5, image 1 de 2 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 5, image 2 de 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 6, image 1 de 3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 6, image 2 de 3 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: étape 6, image 3 de 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
2 autres ont terminé cette réparation.
David R
Membre depuis le 07/20/15
1 152 Réputation
9 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 262
