Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Fascinate Camera Replacement
Ce dont vous avez besoin
  1. Samsung Fascinate Camera Replacement, Back Case: étape 1, image 1 de 3 Samsung Fascinate Camera Replacement, Back Case: étape 1, image 2 de 3 Samsung Fascinate Camera Replacement, Back Case: étape 1, image 3 de 3
    • To remove the back case of the Samsung Galaxy S, you may need a spudger.
    • Identify the slit which is at the bottom edge of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Fascinate Camera Replacement: étape 2, image 1 de 2 Samsung Fascinate Camera Replacement: étape 2, image 2 de 2
    • Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
    Demander à FixBot
  3. Samsung Fascinate Camera Replacement, Battery: étape 3, image 1 de 2 Samsung Fascinate Camera Replacement, Battery: étape 3, image 2 de 2
    • Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
    Demander à FixBot
  4. Samsung Fascinate Camera Replacement, Speaker: étape 4, image 1 de 3 Samsung Fascinate Camera Replacement, Speaker: étape 4, image 2 de 3 Samsung Fascinate Camera Replacement, Speaker: étape 4, image 3 de 3
    • Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
    • If the screws are stuck, use the spudger to pry them out.
    Demander à FixBot
  5. Samsung Fascinate Camera Replacement: étape 5, image 1 de 3 Samsung Fascinate Camera Replacement: étape 5, image 2 de 3 Samsung Fascinate Camera Replacement: étape 5, image 3 de 3
    • Use the plastic opening tool to pry the main case from the LCD touchscreen.
    • Insert the thin edge of the plastic opening tool into the groove between the silver edge and black edge.
    • Run the tool all the way around the edge of the phone until you hear each of the clips detach.
    Demander à FixBot
  6. Samsung Fascinate Camera Replacement: étape 6, image 1 de 3 Samsung Fascinate Camera Replacement: étape 6, image 2 de 3 Samsung Fascinate Camera Replacement: étape 6, image 3 de 3
    • Once the clips are detached, separate the main case from the LCD touchscreen.
    Demander à FixBot
  7. Samsung Fascinate Camera Replacement: étape 7, image 1 de 3 Samsung Fascinate Camera Replacement: étape 7, image 2 de 3 Samsung Fascinate Camera Replacement: étape 7, image 3 de 3
    • Use the spudger to pry out the grey rubber rectangular component from the main case.
    Demander à FixBot
  8. Samsung Fascinate Camera Replacement: étape 8, image 1 de 3 Samsung Fascinate Camera Replacement: étape 8, image 2 de 3 Samsung Fascinate Camera Replacement: étape 8, image 3 de 3
    • Use the spudger to pry along the groove between the speaker and the main case.
    • Once the speaker is unclipped it should pop out easily.
    Demander à FixBot
  9. Samsung Fascinate Camera Replacement, Camera: étape 9, image 1 de 3 Samsung Fascinate Camera Replacement, Camera: étape 9, image 2 de 3 Samsung Fascinate Camera Replacement, Camera: étape 9, image 3 de 3
    • Using the plastic opening tool, you will need to detach the black square component which is boxed in blue.
    • Pry camera unit attached to it off the motherboard.
    Demander à FixBot
3 autres ont terminé cette réparation.
Kevin Carlson
Membre depuis le 04/22/11
236 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 25-25, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-25, Garner Spring 2011
CPSU-GARNER-S11S25G25
4 membres
18 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 4,875
