Aller au contenu principal
Samsung Galaxy A10 Charging Port Replacement
Vidéo d'introduction
  1. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: étape 1, image 1 de 3 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: étape 1, image 2 de 3 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: étape 1, image 3 de 3
    • Remove the SIM Tray.
    • Use plastic tools to separate the back cover.
  2. Samsung Galaxy A10 Charging Port Replacement: étape 2, image 1 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 2, image 2 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 2, image 3 de 3
    • Remove the silver Phillips screws to be able to disassemble the motherboard shields.
  3. Samsung Galaxy A10 Charging Port Replacement: étape 3, image 1 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 3, image 2 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 3, image 3 de 3
    • Disconnect the battery.
    • Remove the screws and the charging board shield.
  4. Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: étape 4, image 1 de 2 Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: étape 4, image 2 de 2
    • Disconnect the Main flex cable and the coaxial antenna cables and remove the charging board.
  5. Samsung Galaxy A10 Charging Port Replacement: étape 5, image 1 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 5, image 2 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 5, image 3 de 3
    • Cover the microphone hole to prevent microphone damage.
    • Use hot air to remove the Micro USB connector.
  6. Samsung Galaxy A10 Charging Port Replacement: étape 6, image 1 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 6, image 2 de 3 Samsung Galaxy A10 Charging Port Replacement: étape 6, image 3 de 3
    • Clean the tin and install the new charging connector.
  7. Samsung Galaxy A10 Charging Port Replacement: étape 7, image 1 de 2 Samsung Galaxy A10 Charging Port Replacement: étape 7, image 2 de 2
    • Clean the board and test the device.
11 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 341 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 540 tutoriels rédigés
Un commentaire
Waste of time unless you're obsessed with soldering. Just buy a complete board. Cheaper, easier and quicker.
[deleted] - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 42
30 derniers jours : 209
Total : 7,097
