Introduction
This guide will give step-by-step instructions for how to not only remove the battery, but replace it with a brand-new one. It will be helpful for devices where the battery is not holding charge or it will not turn on due to battery insufficiency. We aim to provide you with comprehensive instructions for safely removing the old battery and seamlessly installing a new one, also ensuring optimal functionality of your device. This repair can be time consuming and difficult. It will require advanced knowledge to replace the battery.
Special Skills
- Heat Gun Usage
Ce dont vous avez besoin
Remove the SIM card and the SIM card tray.
Use an iOpener or heat gun to warm the adhesive that secures the back cover.
Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
Slide the pick around the entire perimeter.
Remove the back cover.
Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
Use an opening pick to lift out the midframe.
