Aller au contenu principal
Samsung Galaxy A20 Battery Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy A20 Battery Replacement, Back Cover: étape 1, image 1 de 3 Samsung Galaxy A20 Battery Replacement, Back Cover: étape 1, image 2 de 3 Samsung Galaxy A20 Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
  2. Samsung Galaxy A20 Battery Replacement, Battery: étape 2, image 1 de 2 Samsung Galaxy A20 Battery Replacement, Battery: étape 2, image 2 de 2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to lift out the midframe.
  3. Samsung Galaxy A20 Battery Replacement: étape 3, image 1 de 2 Samsung Galaxy A20 Battery Replacement: étape 3, image 2 de 2
    • Use an opening tool to gently pry up the press connectors on both ends of the two ribbon cables.
    • Remove the ribbon cables.
  4. Samsung Galaxy A20 Battery Replacement: étape 4, image 1 de 2 Samsung Galaxy A20 Battery Replacement: étape 4, image 2 de 2
    • Apply a couple of drops of high-concentration isopropyl alcohol at the top of the battery to help loosen the adhesive that secures it.
    • Use an opening pick to gently pry up the battery.
    • Take care not to bend or puncture the battery.
    • Remove the battery.
    • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
Tori Berman
Membre depuis le 02/05/24
448 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 108
Total : 159
