Aller au contenu principal
Samsung Galaxy A20e Display Assembly Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Samsung Galaxy A20e Display Assembly Replacement, Display Touch Screen Assembly Spare part: étape 1, image 1 de 2 Samsung Galaxy A20e Display Assembly Replacement, Display Touch Screen Assembly Spare part: étape 1, image 2 de 2
    • This is Display Touch Screen Assembly with Frame
  2. Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: étape 2, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: étape 2, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Back Cover Removal: étape 2, image 3 de 3
    • Remove the SIM tray
    • To remove the back cover use a plastic opening tool
    • When you remove the back cover, press the Touch ID to unstick it from the back cover
  3. Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: étape 3, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: étape 3, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Fingerprint Sensor Removal: étape 3, image 3 de 3
    • With a Phillips Screwdriver remove all the screws
    • With a Plastic Opening Tool:
    • Remove the Antenna Assembly
    • Disconnect and remove the Touch ID Fingerprint Sensor
  4. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: étape 4, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: étape 4, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Cover Removal: étape 4, image 3 de 3
    • Remove the Logic Board Plastic Cover
    • Remove the Sup-board Plastic Cover
  5. Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: étape 5, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: étape 5, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Test the New Spare part: étape 5, image 3 de 3
    • Its time to test the new spare part
    • Do not forget to disconnect the battery before you start working on the device.
  6. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: étape 6, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: étape 6, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 1: étape 6, image 3 de 3
    • Disconnect the Battery
    • Disconnect the Sup-board Flex Cable
    • Disconnect the Coaxial Antenna Cables. Do it very carefully because you can easily damage them
  7. Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: étape 7, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: étape 7, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Logic Board Removal - Part 2: étape 7, image 3 de 3
    • Remove the Sup-board Flex Cable
    • Disconnect the Volume buttons Flex Cable
    • Gently remove the Logic board. Be careful for the cameras
  8. Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: étape 8, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: étape 8, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Sup-board removal: étape 8, image 3 de 3
    • Use Hot air to soften the adhesive and gently remove the sup-bord
    • Its better to use a plastic tools
  9. Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: étape 9, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: étape 9, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Battery Removal: étape 9, image 3 de 3
    • To remove the Battery use a few drops of alcohol and warm the device.
  10. Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: étape 10, image 1 de 3 Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: étape 10, image 2 de 3 Samsung Galaxy A20e Display Assembly Replacement, Transfer the Receiver, Loudspeaker and the Vibration-motor: étape 10, image 3 de 3
    • Now you have to transfer:
    • Receiber
    • Vibromotor
    • Loudspeacker
    • Remove the transport tapes from:
    • Silicon Thermal Pad
    • Front Camera Hole
    • Use Hot Air to do this easily
  11. Samsung Galaxy A20e Display Assembly Replacement, Battery: étape 11, image 1 de 1
    • Use Double side Adhesive tape to install the battery to the new frame
  12. Samsung Galaxy A20e Display Assembly Replacement: étape 12, image 1 de 1
    • "All's Well That Ends Well."
20 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
194 021 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 697 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 14
30 derniers jours : 62
Total : 17,304
