Aller au contenu principal
Introduction
Use this guide to remove the back cover on your Samsung Galaxy A40 .
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Apply a  heated iOpener to the back cover to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
    • Apply a heated iOpener to the back cover to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Secure a suction handle to the right edge of the back cover, as close to the edge as possible. If the phone's back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • If the phone's back cover is damaged, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  3. Slide the opening pick to the bottom right corner and leave it in place to prevent the adhesive from resealing. Slide the opening pick to the bottom right corner and leave it in place to prevent the adhesive from resealing.
    • Slide the opening pick to the bottom right corner and leave it in place to prevent the adhesive from resealing.
  4. Insert a second opening pick at the bottom right corner. Slide the opening pick along the right edge of your phone to cut the adhesive beneath the back cover.
    • Insert a second opening pick at the bottom right corner.
    • Slide the opening pick along the right edge of your phone to cut the adhesive beneath the back cover.
    • Leave the opening pick in the top right corner.
    • At this point of the back cover removal feel free to remove the suction cup or continue to use it for a better grip.
  5. Insert a third opening pick at the top right corner of your phone. Slide the opening pick along the top edge of your phone to cut the adhesive.
    • Insert a third opening pick at the top right corner of your phone.
    • Slide the opening pick along the top edge of your phone to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
  6. Insert a fourth opening pick at the top left corner of your phone. Slide the opening pick along the left edge of your phone to cut the adhesive.
    • Insert a fourth opening pick at the top left corner of your phone.
    • Slide the opening pick along the left edge of your phone to cut the adhesive.
    • Leave the opening pick in the bottom left corner.
  7. Insert a fifth opening pick to cut the remaining adhesive at the bottom edge of your phone. In order to cut all the adhesive at the bottom edge of the device, you need to insert the opening pick about 0.4 inch (1cm).
    • Insert a fifth opening pick to cut the remaining adhesive at the bottom edge of your phone.
    • In order to cut all the adhesive at the bottom edge of the device, you need to insert the opening pick about 0.4 inch (1cm).
  8. Remove the back cover. Remove the back cover.
    • Remove the back cover.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
120 653 Réputation
504 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
146 membres
17 254 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 25
30 derniers jours : 148
Total : 2,039
