Aller au contenu principal
Samsung Galaxy A40 Charging Board Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: étape 1, image 1 de 2 Samsung Galaxy A40 Charging Board Replacement, Charging Dock / Charging Board: étape 1, image 2 de 2
    • The spare part: Daughter board with Charging port, Microphone, Main flex cable connector, display connector, 3G, 4G antennas
  2. Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: étape 2, image 1 de 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: étape 2, image 2 de 3 Samsung Galaxy A40 Charging Board Replacement, Remove the Back Cover: étape 2, image 3 de 3
    • Turn off the device by pressing and holding the small button on the right side. After a few seconds, press the Power Off button and wait until the device has completely shut off
    • To soften the adhesive, use a heat gun or heating pad to warm up the device.
    • Use a Spudger (Or playing card) , Suction Cup, and Isopropyl alcohol to separate the back cover.
  3. Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: étape 3, image 1 de 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: étape 3, image 2 de 3 Samsung Galaxy A40 Charging Board Replacement, Remove the  Sim Card Tray/Fingerprint Sensor: étape 3, image 3 de 3
    • Be very careful when removing the ribbons in this step! Damaging the ribbons may cause parts of your phone to stop working
    • Remove the SIM tray.
    • Remove the plastic cover that covers the Fingerprint flex connector.
    • Disconnect the Fingerprint Sensor.
  4. Samsung Galaxy A40 Charging Board Replacement: étape 4, image 1 de 3 Samsung Galaxy A40 Charging Board Replacement: étape 4, image 2 de 3 Samsung Galaxy A40 Charging Board Replacement: étape 4, image 3 de 3
    • Remove the 13 screws
    • Remove the back cover
  5. Samsung Galaxy A40 Charging Board Replacement: étape 5, image 1 de 2 Samsung Galaxy A40 Charging Board Replacement: étape 5, image 2 de 2
    • Disconnect the Main flex cable, Display flex cable and the Coaxial antenna cable.
    • Remove the black screw securing the charging board.
  6. Samsung Galaxy A40 Charging Board Replacement: étape 6, image 1 de 3 Samsung Galaxy A40 Charging Board Replacement: étape 6, image 2 de 3 Samsung Galaxy A40 Charging Board Replacement: étape 6, image 3 de 3
    • Use Plastic tool to separate the charging board from the frame.
    • Warm the charging board slightly to make it easier to disassemble.
    • Now, install the new board and test the device.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 545 tutoriels rédigés
Un commentaire
Replaced port but phone now doesn't recognise sim can use WhatsApp though
Ann Sayer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 111
Total : 5,505
