Aller au contenu principal
Introduction
S5830, S5830i - how to disassemble and change / replace the loudspeaker, earpiece, main camera, LCD Display, Touch screen Digitizer Glass, etc.
Vidéo d'introduction
  1. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: étape 1, image 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: étape 1, image 2 de 2
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory card.
  2. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 2, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 2, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 2, image 3 de 3
    • Remove the 7 Phillips screws.
    • Use a plastic tool to remove the back cover.
    • vibrating motor
  3. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 3, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 3, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 3, image 3 de 3
    • Disconnect the earpiece & light sensor flex cable.
    • Take off the Volume Up/Down buttons flex cable.
    • Do the same with the Power button flex cable.
    • Be careful don't brake the flex cables.
  4. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 4, image 3 de 3
    • Lift the microphone.
    • Lift the board from the right side and disconnect the LCD display flex cable.
    • Remove the board from the middle frame.
  5. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 5, image 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 5, image 2 de 2
    • This is the main camera.
  6. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 6, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 6, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 6, image 3 de 3
    • This is the loudspeaker & audio jack connector module.
  7. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 7, image 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 7, image 2 de 2
    • Loudspeaker and light sensor module,
  8. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 8, image 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 8, image 2 de 2
    • Disconnect the touch screen flex cable.
  9. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 9, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 9, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 9, image 3 de 3
    • Use a hair dryer and warm the touch screen glass to make adhesive soften.
    • Use a plastic tool for separating the glass from the middle frame.
  10. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 10, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 10, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 10, image 3 de 3
    • Again by using a plastic tool, separate the LCD display from the middle frame.
  11. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 11, image 1 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 11, image 2 de 3 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 11, image 3 de 3
    • Clean the middle frame and install the LCD display.
  12. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 12, image 1 de 2 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 12, image 2 de 2
    • Install the touch screen and start with reassembling.
  13. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: étape 13, image 1 de 1
    • That is all.
    • Did you do it successfully?
23 autres ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
185 706 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
307 membres
1 128 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 32
Total : 8,664
