Aller au contenu principal
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: étape 1, image 1 de 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: étape 1, image 2 de 3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: étape 1, image 3 de 3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: étape 2, image 1 de 2 Samsung Galaxy Alpha Battery Replacement, Battery: étape 2, image 2 de 2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
10 autres ont terminé cette réparation.
Jon Brausch
Membre depuis le 01/20/15
1 542 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-17, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
4 membres
5 tutoriels rédigés
2 commentaires
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - Réponse
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 31
Total : 4,994
