Introduction
Disassemble a Samsung Galaxy Amp 2 in order to replace a faulty home button. You may want to replace the home button if it is damaged or unresponsive. The most time consuming step is removing the screen, which is a bit tricky. You will need angled tweezers, four plastic opening tools, and a heat gun or blow dryer. You will also need a PH000 screwdriver in order to unscrew the motherboard, which holds the home button in place.
Ce dont vous avez besoin
Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
Lift upwards and gently pry the rear panel off of the phone.
Outil utilisé dans cette étape :Tweezers$3.99
Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
Disconnect the connector piece from the back panel.
Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
Push from the back panel to remove the bottom part of the motherboard.
Push from the front panel to remove the top part of the motherboard.
Pull the black tab that is located on the bottom of the motherboard.
Push the home button out of the black tab.
