Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Amp 2 Home Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Amp 2 Home Button Replacement, Battery: étape 1, image 2 de 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Amp 2 Home Button Replacement: étape 2, image 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement: étape 2, image 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement: étape 2, image 3 de 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
    Demander à FixBot
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: étape 3, image 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: étape 3, image 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    $3.99
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
    Demander à FixBot
  4. Samsung Galaxy Amp 2 Home Button Replacement: étape 4, image 1 de 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
    Demander à FixBot
  5. Samsung Galaxy Amp 2 Home Button Replacement: étape 5, image 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement: étape 5, image 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement: étape 5, image 3 de 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
    Demander à FixBot
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: étape 6, image 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: étape 6, image 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: étape 6, image 3 de 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
    Demander à FixBot
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: étape 7, image 1 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: étape 7, image 2 de 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: étape 7, image 3 de 3
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
    Demander à FixBot
Cory Nickolatos
Membre depuis le 07/12/18
430 Réputation
4 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Membre de l'équipe UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 38
Total : 849
