Begin by turn the device over to it's back, with the screen facing down.
  • Begin by turn the device over to it's back, with the screen facing down.
Ajouter un commentaire
At the top of the device there is a small notch that is used to remove the battery door. Using a pry tool or your fingernail, pry off the battery door from the main housing.
  • At the top of the device there is a small notch that is used to remove the battery door.
  • Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side. Using a pry tool or your fingernail, pry the battery up towards you. You have now removed the battery!
  • Place the battery door to the side.
  • Using a pry tool or your fingernail, pry the battery up towards you.
  • You have now removed the battery!
Make sure when replacing the battery that the arrow on the bottom is facing down.
  • Make sure when replacing the battery that the arrow on the bottom is facing down.
Remove the 6 Phillips head screws that hold the rear housing in place.
  • Remove the 6 Phillips head screws that hold the rear housing in place.
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Lift the rear housing from the display assembly.
  • Lift the rear housing from the display assembly.
4 autre(s) ont terminé cette réparation.
Josh Forester
Membre depuis le 28/11/2010
2 309 Réputation
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 147
