Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Centura Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Centura Screen Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Centura Screen Replacement, Battery: étape 1, image 2 de 2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Centura Screen Replacement: étape 2, image 1 de 3 Samsung Galaxy Centura Screen Replacement: étape 2, image 2 de 3 Samsung Galaxy Centura Screen Replacement: étape 2, image 3 de 3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
    Demander à FixBot
  3. Samsung Galaxy Centura Screen Replacement, Screen: étape 3, image 1 de 1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
    Demander à FixBot
  4. Samsung Galaxy Centura Screen Replacement: étape 4, image 1 de 2 Samsung Galaxy Centura Screen Replacement: étape 4, image 2 de 2
    • Locate the indentation on the side of the device and gently insert the plastic opening tool into it. With a firm prying motion, the plastic should begin to come apart.
    • Gently pull apart the plastic, and set it aside. The phone should now appear as shown in the second picture.
    Demander à FixBot
  5. Samsung Galaxy Centura Screen Replacement: étape 5, image 1 de 3 Samsung Galaxy Centura Screen Replacement: étape 5, image 2 de 3 Samsung Galaxy Centura Screen Replacement: étape 5, image 3 de 3
    • Pull back the clips located on the right hand side and the upper left side of the phone as shown.
    • After releasing the clips, gently raise the motherboard, exposing the screen from the back.
    Demander à FixBot
  6. Samsung Galaxy Centura Screen Replacement: étape 6, image 1 de 3 Samsung Galaxy Centura Screen Replacement: étape 6, image 2 de 3 Samsung Galaxy Centura Screen Replacement: étape 6, image 3 de 3
    • Gently insert the metal spudger towards the top edge of the back side of the screen.
    • Gently apply pressure to raise the screen from its held position. Continue pulling gently upwards from one side until the screen has been completely removed.
    Demander à FixBot
Anthony Maldonado
Membre depuis le 02/28/17
134 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S2-G5, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S2-G5, Nance Spring 2017
USFT-NANCE-S17S2G5
3 membres
11 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 32
Total : 1,025
