Aller au contenu principal
Samsung Galaxy Centura Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Centura Speaker Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Centura Speaker Replacement, Battery: étape 1, image 2 de 2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Speaker Replacement: étape 2, image 1 de 3 Samsung Galaxy Centura Speaker Replacement: étape 2, image 2 de 3 Samsung Galaxy Centura Speaker Replacement: étape 2, image 3 de 3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Speaker Replacement, External Speaker: étape 3, image 1 de 1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Speaker Replacement: étape 4, image 1 de 1
    • Gently insert the plastic opening tool into the notch on the side of the device. Apply a firm prying motion to pop open and remove the plastic casing.
  5. Samsung Galaxy Centura Speaker Replacement: étape 5, image 1 de 2 Samsung Galaxy Centura Speaker Replacement: étape 5, image 2 de 2
    • Locate the black plastic clip at the top of the removed plastic casing. Use the metal spudger to release this clip.
    • Apply a firm prying motion to remove the pink plastic section. The external speaker is a part of this assembly.
Mohsen Alshammari
Membre depuis le 02/28/17
102 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S2-G5, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S2-G5, Nance Spring 2017
USFT-NANCE-S17S2G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 273
