Aller au contenu principal
Samsung Galaxy Core Prime Back Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Core Prime Back Camera Replacement, Battery: étape 1, image 1 de 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Back Camera Replacement: étape 2, image 1 de 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Back Camera Replacement: étape 3, image 1 de 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Back Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: étape 4, image 2 de 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Back Camera Replacement: étape 5, image 1 de 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: étape 6, image 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement, Rear Camera: étape 6, image 2 de 2
    • Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
  7. Samsung Galaxy Core Prime Back Camera Replacement: étape 7, image 1 de 1
    • Heat the frame with a heat gun or hair dryer until the adhesive is loose.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Back Camera Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    iFixit Opening Tool
    $1.99
    J'achète
  9. Samsung Galaxy Core Prime Back Camera Replacement: étape 9, image 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: étape 9, image 2 de 2
    J'achète
    • Disconnect the power ribbon on the left side of the phone either with your fingers or tweezers
  10. Samsung Galaxy Core Prime Back Camera Replacement: étape 10, image 1 de 1
    iFixit Opening Tool
    $1.99
    J'achète
  11. Samsung Galaxy Core Prime Back Camera Replacement: étape 11, image 1 de 2 Samsung Galaxy Core Prime Back Camera Replacement: étape 11, image 2 de 2
    Metal Spudger
    $2.99
    J'achète
    • Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
2 autres ont terminé cette réparation.
Adrian Sanchez
Membre depuis le 10/09/18
169 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S11-G2, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S11-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 28
Total : 1,482
