Aller au contenu principal
Samsung Galaxy Core Prime Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Core Prime Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn the smartphone off by using the power button on the right-hand side.
  2. Samsung Galaxy Core Prime Screen Replacement: étape 2, image 1 de 1
    • Turn the smartphone over so that the rear camera is face up.
  3. Samsung Galaxy Core Prime Screen Replacement: étape 3, image 1 de 1
    • Use your fingernail or a flat tool to lift the back cover.
  4. Samsung Galaxy Core Prime Screen Replacement: étape 4, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement: étape 4, image 2 de 2
    • Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
  5. Samsung Galaxy Core Prime Screen Replacement: étape 5, image 1 de 1
    • Use your fingernail or a flat tool to lift the battery out.
  6. Samsung Galaxy Core Prime Screen Replacement, Screen: étape 6, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement, Screen: étape 6, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the eight 4 mm screws from the midframe.
  7. Samsung Galaxy Core Prime Screen Replacement: étape 7, image 1 de 1
    • Use a heat gun or hair dryer to loosen the adhesive between the midframe and the rest of the device.
    • Take care when using these heat tools.
  8. Samsung Galaxy Core Prime Screen Replacement: étape 8, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    iFixit Opening Tool
    $1.99
    J'achète
  9. Samsung Galaxy Core Prime Screen Replacement: étape 9, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement: étape 9, image 2 de 2
    J'achète
    • Use tweezers to disconnect the power ribbon from the motherboard.
  10. Samsung Galaxy Core Prime Screen Replacement: étape 10, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement: étape 10, image 2 de 2
    • Use tweezers or your hand to remove the audiojack.
  11. Samsung Galaxy Core Prime Screen Replacement: étape 11, image 1 de 1
    iFixit Opening Tool
    $1.99
    J'achète
  12. Samsung Galaxy Core Prime Screen Replacement: étape 12, image 1 de 1
    iFixit Opening Tool
    $1.99
    J'achète
    • Lift the plastic panel that separates the digitizer and the motherboard with an iFixit Opening Tool
  13. Samsung Galaxy Core Prime Screen Replacement: étape 13, image 1 de 3 Samsung Galaxy Core Prime Screen Replacement: étape 13, image 2 de 3 Samsung Galaxy Core Prime Screen Replacement: étape 13, image 3 de 3
    iFixit Opening Tool
    $1.99
    J'achète
  14. Samsung Galaxy Core Prime Screen Replacement: étape 14, image 1 de 2 Samsung Galaxy Core Prime Screen Replacement: étape 14, image 2 de 2
    • Use tweezers to disconnect the digitizer.
7 autres ont terminé cette réparation.
Cody Coombs
Membre depuis le 10/02/18
257 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S11-G2, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S11-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G2
4 membres
5 tutoriels rédigés
Un commentaire
What if the phone does not come back on after assembly
nfl.ny.la.313 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 43
Total : 2,516
