Aller au contenu principal
Samsung Galaxy Core Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Core Screen Replacement, Screen: étape 1, image 1 de 3 Samsung Galaxy Core Screen Replacement, Screen: étape 1, image 2 de 3 Samsung Galaxy Core Screen Replacement, Screen: étape 1, image 3 de 3
    • Flip the phone over and use your fingernail or an opening tool to remove the back cover.
  2. Samsung Galaxy Core Screen Replacement: étape 2, image 1 de 2 Samsung Galaxy Core Screen Replacement: étape 2, image 2 de 2
    • Remove the battery.
    • If your phone has a SIM card or MicroSD card, remove them.
  3. Samsung Galaxy Core Screen Replacement: étape 3, image 1 de 1
    • Remove the 9 Phillips #00 screws from the mid-frame.
  4. Samsung Galaxy Core Screen Replacement: étape 4, image 1 de 2 Samsung Galaxy Core Screen Replacement: étape 4, image 2 de 2
    • Use an opening pick to pry off the mid frame.
  5. Samsung Galaxy Core Screen Replacement: étape 5, image 1 de 2 Samsung Galaxy Core Screen Replacement: étape 5, image 2 de 2
    • Disconnect the following ribbon cables from the motherboard:
    • The digitizer and LCD assembly.
    • Headphone Jack and Earpiece.
    • Daughter board flex cable.
    • Antenna connector.
  6. Samsung Galaxy Core Screen Replacement: étape 6, image 1 de 3 Samsung Galaxy Core Screen Replacement: étape 6, image 2 de 3 Samsung Galaxy Core Screen Replacement: étape 6, image 3 de 3
    • Use a plastic opening tool to remove the motherboard.
  7. Samsung Galaxy Core Screen Replacement: étape 7, image 1 de 3 Samsung Galaxy Core Screen Replacement: étape 7, image 2 de 3 Samsung Galaxy Core Screen Replacement: étape 7, image 3 de 3
    • Remove the single Phillips screw that secures the daughterboard.
    • Remove the daughterboard.
    • The flex cable is glued, so exercise extreme caution, as excessive force can damage the cable.
  8. Samsung Galaxy Core Screen Replacement: étape 8, image 1 de 3 Samsung Galaxy Core Screen Replacement: étape 8, image 2 de 3 Samsung Galaxy Core Screen Replacement: étape 8, image 3 de 3
    • Use an opening pick to remove the audio jack.
  9. Samsung Galaxy Core Screen Replacement: étape 9, image 1 de 2 Samsung Galaxy Core Screen Replacement: étape 9, image 2 de 2
    • Disconnect the digitizer's ribbon cable.
  10. Samsung Galaxy Core Screen Replacement: étape 10, image 1 de 1
    • Push the earpiece mesh outwards to release it.
  11. Samsung Galaxy Core Screen Replacement: étape 11, image 1 de 1
    • Use a heat gun or an iOpener to heat the digitizer and soften the glue securing it.
    • Use an opening pick to break up the glue around the edges of the digitizer.
    • You may apply more heat if needed.
    • Remove the digitizer and any broken glass.
90 autres ont terminé cette réparation.
ivan coene
Membre depuis le 03/12/14
3 006 Réputation
2 tutoriels rédigés
11 commentaires
yes, but where can I buy the screen replacement?
Roxannie - Réponse
I bought it on Ebay...
ivan coene - Réponse
Comment root galaxy core prime g361f android 5.1.1
soulaemen - Réponse
Follow the instructions in reverse order? Do you need glue for the new screen? What kind of glue? How is it applied?
Thomas McGuigan - Réponse
Nor do they show how the new digitizer plugs in...
chris smith -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 20
Total : 116,933
