Aller au contenu principal
Introduction
In the simple steps below, you will be able to remove your battery out of the Express 3.
  1. Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone. Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Once the cover is removed, locate the battery that reads "SAMSUNG." Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery. Do not use a metal tool, as it can cause injury.
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
3 autres ont terminé cette réparation.
Kellie Speck
Membre depuis le 24/04/2018
121 Réputation
1 tutoriel rédigé
2 commentaires
Petra:
Hi I’m from Central South America and I recently got this phone for my birthday. I dropped it while at the swimming pool for my party THE SAME DAY I GOT IT and I was really sad. #sad I found your steps a-maz-ing. It helped me not only unclog the water that had corroded the battery inside, but I was able to successfully dry my phone out and replace it without too much hassle. The pictures were especially helpful because English is my fourth language. Thank you Kellie!
Mack Johnson - Réponse
I am so thrilled!
-Kels
Stephen Pettinger -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 900
