Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Express 3 Home Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Express 3 Home Button Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement, Battery: étape 1, image 2 de 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Express 3 Home Button Replacement: étape 2, image 1 de 3 Samsung Galaxy Express 3 Home Button Replacement: étape 2, image 2 de 3 Samsung Galaxy Express 3 Home Button Replacement: étape 2, image 3 de 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
    Demander à FixBot
  3. Samsung Galaxy Express 3 Home Button Replacement, Screen: étape 3, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement, Screen: étape 3, image 2 de 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
    Demander à FixBot
  4. Samsung Galaxy Express 3 Home Button Replacement: étape 4, image 1 de 1
    • Detach the screen connector.
    Demander à FixBot
  5. Samsung Galaxy Express 3 Home Button Replacement: étape 5, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement: étape 5, image 2 de 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
    Demander à FixBot
  6. Samsung Galaxy Express 3 Home Button Replacement: étape 6, image 1 de 3 Samsung Galaxy Express 3 Home Button Replacement: étape 6, image 2 de 3 Samsung Galaxy Express 3 Home Button Replacement: étape 6, image 3 de 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
    Demander à FixBot
  7. Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): étape 7, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement, Back and Recent Apps Touch Sensor Button(s): étape 7, image 2 de 2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
    Demander à FixBot
  8. Samsung Galaxy Express 3 Home Button Replacement, Home Button: étape 8, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement, Home Button: étape 8, image 2 de 2
    • Use a #0 Phillips bit screwdriver to remove the four screws from the black, plastic piece surrounding the home button.
    • All four screws are the same size.
    Demander à FixBot
  9. Samsung Galaxy Express 3 Home Button Replacement: étape 9, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement: étape 9, image 2 de 2
    • Using a sharp plastic tool such as a guitar pick or prying tool to pop up and remove the black, plastic piece.
    • Do not use a metal tool as it can be dangerous to you or the motherboard.
    Demander à FixBot
  10. Samsung Galaxy Express 3 Home Button Replacement: étape 10, image 1 de 2 Samsung Galaxy Express 3 Home Button Replacement: étape 10, image 2 de 2
    • The white button will be connected to the black piece.
    • Slightly bend the black piece and gently push the white button until it pops out of the black, plastic piece.
    Demander à FixBot
Mack Johnson
Membre depuis le 04/05/18
996 Réputation
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 48
Total : 788
