Aller au contenu principal
Samsung Galaxy Express 3 Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Express 3 Screen Replacement, Battery: étape 1, image 1 de 2 Samsung Galaxy Express 3 Screen Replacement, Battery: étape 1, image 2 de 2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Screen Replacement: étape 2, image 1 de 3 Samsung Galaxy Express 3 Screen Replacement: étape 2, image 2 de 3 Samsung Galaxy Express 3 Screen Replacement: étape 2, image 3 de 3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Screen Replacement, Screen: étape 3, image 1 de 2 Samsung Galaxy Express 3 Screen Replacement, Screen: étape 3, image 2 de 2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Screen Replacement: étape 4, image 1 de 1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Screen Replacement: étape 5, image 1 de 2 Samsung Galaxy Express 3 Screen Replacement: étape 5, image 2 de 2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Screen Replacement: étape 6, image 1 de 3 Samsung Galaxy Express 3 Screen Replacement: étape 6, image 2 de 3 Samsung Galaxy Express 3 Screen Replacement: étape 6, image 3 de 3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
7 autres ont terminé cette réparation.
Mack Johnson
Membre depuis le 04/05/18
996 Réputation
6 tutoriels rédigés
2 commentaires
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Rudolph Mc Alister - Réponse
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
Faith Dockery -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 27
Total : 3,525
