Aller au contenu principal
Samsung Galaxy Fame S6812i Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: étape 1, image 1 de 1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: étape 2, image 1 de 1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: étape 3, image 1 de 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: étape 3, image 2 de 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: étape 3, image 3 de 3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: étape 4, image 1 de 2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: étape 4, image 2 de 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: étape 5, image 1 de 1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: étape 6, image 1 de 1
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
6 autres ont terminé cette réparation.
Charles
Membre depuis le 10/07/14
133 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 993
