Aller au contenu principal
Samsung Galaxy Gear Display Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Gear Display Assembly Replacement, Display Housing: étape 1, image 1 de 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Assembly Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy Gear Display Assembly Replacement: étape 3, image 2 de 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Display Assembly Replacement, Motherboard: étape 4, image 1 de 2 Samsung Galaxy Gear Display Assembly Replacement, Motherboard: étape 4, image 2 de 2
    • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
  5. Samsung Galaxy Gear Display Assembly Replacement: étape 5, image 1 de 1
    • The motherboard is attached to the display using an adhesive
    • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
  6. Samsung Galaxy Gear Display Assembly Replacement: étape 6, image 1 de 2 Samsung Galaxy Gear Display Assembly Replacement: étape 6, image 2 de 2
    • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
    • Slowly pry up the motherboard from the display.
  7. Samsung Galaxy Gear Display Assembly Replacement, Display Assembly: étape 7, image 1 de 1
    • The display assembly is now separated and can be replaced
2 autres ont terminé cette réparation.
Joe
Membre depuis le 04/11/16
279 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 1-9, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,582
