Aller au contenu principal
Samsung Galaxy Gear Display Housing Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Gear Display Housing Replacement, Display Housing: étape 1, image 1 de 1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Housing Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Housing Replacement: étape 3, image 1 de 2 Samsung Galaxy Gear Display Housing Replacement: étape 3, image 2 de 2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
Dalt Lasell
Membre depuis le 04/12/16
543 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 1-9, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 1-9, Maness Spring 2016
CPSU-MANESS-S16S1G9
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,266
