Introduction
If the motherboard needs to be replaced, this guide will demonstrate how to do so.
Ce dont vous avez besoin
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
2 autres ont terminé cette réparation.
Un commentaire
Had to build a cradle, keep breaking, do not know out the 5 brass pronges which is pisitive and negative, how is there no schematic of the gear watch??
