Aller au contenu principal
Samsung Galaxy Grand Prime Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Battery: étape 1, image 3 de 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: étape 2, image 1 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: étape 2, image 2 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Remove the battery.: étape 2, image 3 de 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: étape 3, image 1 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: étape 3, image 2 de 3 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Midframe: étape 3, image 3 de 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 4, image 1 de 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 4, image 2 de 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 5, image 1 de 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 5, image 2 de 2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: étape 6, image 1 de 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement, Earpiece Speaker: étape 6, image 2 de 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  7. Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 7, image 1 de 2 Samsung Galaxy Grand Prime Earpiece Speaker Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Gently pull on the connector with the tweezers until the speaker comes off.
23 autres ont terminé cette réparation.
Kyle Ruff
Membre depuis le 02/04/16
6 794 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 25
Total : 12,053
