Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Grand Prime Micro USB Port Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: étape 1, image 3 de 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: étape 2, image 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: étape 2, image 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: étape 2, image 3 de 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    Demander à FixBot
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: étape 3, image 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: étape 3, image 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: étape 3, image 3 de 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    Demander à FixBot
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 4, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 4, image 2 de 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
    Demander à FixBot
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 5, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 5, image 2 de 2
    • Make sure that you detach the mid-frame from the inside too.
    Demander à FixBot
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: étape 6, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: étape 6, image 2 de 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    Demander à FixBot
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: étape 7, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: étape 7, image 2 de 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
    Demander à FixBot
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 8, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • Gently pull on the connector with the tweezers until the speaker comes off.
    Demander à FixBot
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: étape 9, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: étape 9, image 2 de 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
    Demander à FixBot
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 10, image 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 10, image 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 10, image 3 de 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
    Demander à FixBot
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 11, image 1 de 2 Samsung Galaxy Grand Prime Micro USB Port Replacement: étape 11, image 2 de 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
    Demander à FixBot
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: étape 12, image 1 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: étape 12, image 2 de 3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: étape 12, image 3 de 3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
    Demander à FixBot
35 autres ont terminé cette réparation.
Kyle Ruff
Membre depuis le 02/04/16
6 851 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 48
Total : 35,864
