Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Grand Prime Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Grand Prime Motherboard Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: étape 2, image 1 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: étape 2, image 2 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Remove the battery.: étape 2, image 3 de 3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    Demander à FixBot
  3. Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: étape 3, image 1 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: étape 3, image 2 de 3 Samsung Galaxy Grand Prime Motherboard Replacement, Midframe: étape 3, image 3 de 3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    Demander à FixBot
  4. Samsung Galaxy Grand Prime Motherboard Replacement: étape 4, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement: étape 4, image 2 de 2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
    Demander à FixBot
  5. Samsung Galaxy Grand Prime Motherboard Replacement: étape 5, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement: étape 5, image 2 de 2
    • Make sure that you detach the mid-frame from the inside too.
    Demander à FixBot
  6. Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: étape 6, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement, Headphone Jack/Speaker Assembly: étape 6, image 2 de 2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    Demander à FixBot
  7. Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: étape 7, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement, Earpiece Speaker: étape 7, image 2 de 2
    • Use the plastic opening tool to unhook the ribbon cable clip.
    Demander à FixBot
  8. Samsung Galaxy Grand Prime Motherboard Replacement: étape 8, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • Gently pull on the connector with the tweezers until the speaker comes off.
    Demander à FixBot
  9. Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: étape 9, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
    Demander à FixBot
  10. Samsung Galaxy Grand Prime Motherboard Replacement: étape 10, image 1 de 3 Samsung Galaxy Grand Prime Motherboard Replacement: étape 10, image 2 de 3 Samsung Galaxy Grand Prime Motherboard Replacement: étape 10, image 3 de 3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
    Demander à FixBot
  11. Samsung Galaxy Grand Prime Motherboard Replacement: étape 11, image 1 de 2 Samsung Galaxy Grand Prime Motherboard Replacement: étape 11, image 2 de 2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
    Demander à FixBot
86 autres ont terminé cette réparation.
Kyle Ruff
Membre depuis le 02/04/16
6 851 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 membres
12 tutoriels rédigés
13 commentaires de tutoriel
After fixing all the screen, for some reason the LCD was turning on but it showed black and i dont know if is because im missing a screw or because the LCD doesnt work?
Glo - Réponse Partager
lol this is likely because you ruined the lcd. this tutorial forgot to mention that it is essential to apply heat, as the midframe is adhered on to the inner component.
connectedcellrepair - Réponse Partager
Just need to get a idea on this phone, the silver backing thats usually stuck to the mid frame, when pulling out the old lcd this also came with it.
My question is whether or not that needs to replaced?
Also it changes screens all on its on.
Lisa Yates - Réponse Partager
My grand prime 4g board damage
Rakesh - Réponse Partager
My grand prime 4g mother board damage
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 92
Total : 55,382
