Introduction
If you need to remove the midframe to gain access to internal components such as the motherboard, front camera, rear camera, and daughterboard, this guide will do the trick!
Pièces
Aucune pièce nécessaire.
Insert a finger nail or plastic opening tool between the back cover and the device.
  • Insert a finger nail or plastic opening tool between the back cover and the device.
  • Gently pry the rear cover off of the back of the phone.
Ajouter un commentaire
Using a finger, pull the SIM card down out of its slot.
  • Using a finger, pull the SIM card down out of its slot.
  • Remove the SIM card.
  • The pictured device is missing the SIM card and battery.
  • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  • Insert a plastic opening tool between the screen and the back of the device.
  • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
  • Gently pry the main assembly from the midframe of the device.
  • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
2 autre(s) ont terminé cette réparation.
Sean Kramer
Membre depuis le 14/02/2018
793 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 26
30 derniers jours : 86
Total : 243
