Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy J1 Rear Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy J1 Rear Camera Replacement, Midframe: étape 1, image 1 de 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy J1 Rear Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy J1 Rear Camera Replacement: étape 2, image 2 de 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
    Demander à FixBot
  3. Samsung Galaxy J1 Rear Camera Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    Demander à FixBot
  4. Samsung Galaxy J1 Rear Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 4, image 3 de 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
    Demander à FixBot
  5. Samsung Galaxy J1 Rear Camera Replacement, Rear Camera: étape 5, image 1 de 2 Samsung Galaxy J1 Rear Camera Replacement, Rear Camera: étape 5, image 2 de 2
    • Use the flat end of a spudger to disconnect the ear speaker connector from the motherboard.
    Demander à FixBot
  6. Samsung Galaxy J1 Rear Camera Replacement: étape 6, image 1 de 2 Samsung Galaxy J1 Rear Camera Replacement: étape 6, image 2 de 2
    • Use the flat end of a spudger to disconnect the digitizer connector from the motherboard.
    Demander à FixBot
  7. Samsung Galaxy J1 Rear Camera Replacement: étape 7, image 1 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 7, image 2 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 7, image 3 de 3
    • Use a plastic opening tool to gently pry under the motherboard.
    • Remove motherboard.
    Demander à FixBot
  8. Samsung Galaxy J1 Rear Camera Replacement: étape 8, image 1 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 8, image 2 de 3 Samsung Galaxy J1 Rear Camera Replacement: étape 8, image 3 de 3
    • Use the flat end of a spudger to disconnect the rear camera from the motherboard.
    • Remove the rear camera.
    Demander à FixBot
Sean Kramer
Membre depuis le 02/14/18
1 632 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 49
Total : 2,424
