Ce dont vous avez besoin
Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
Outil utilisé dans cette étape :Plastic Cards$2.99
While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
Locate all eleven screws attaching the metal plate to the frame, and remove them using a PH00 screwdriver bit.
Keep track of the eleven screws they are essential to close the phone back again.
2 autres ont terminé cette réparation.
