Aller au contenu principal
Introduction
This guide will describe how to remove and replace the home key on the Samsung Galaxy J3.
Pièces
Aucune pièce spécifiée.
  1. Samsung Galaxy J3 Home Key Replacement, Home Key: étape 1, image 1 de 1
    • Separate the back casing from the phone by carefully using your fingers to pry them apart.
  2. Samsung Galaxy J3 Home Key Replacement: étape 2, image 1 de 1
    • Remove the battery.
  3. Samsung Galaxy J3 Home Key Replacement: étape 3, image 1 de 1
    • Remove all ten screws by using a Phillips #000 screwdriver.
  4. Samsung Galaxy J3 Home Key Replacement: étape 4, image 1 de 1
    • Use the flat side of a spudger to remove the middle frame bezel.
    • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
  5. Samsung Galaxy J3 Home Key Replacement: étape 5, image 1 de 1
    • Gently pull the glass up from the side of the phone and push the home button out.
    • When you pull the glass up, it will make a popping sound. This is normal.
  6. Samsung Galaxy J3 Home Key Replacement: étape 6, image 1 de 1
    • Replace the home button and press the glass back in place.
3 autres ont terminé cette réparation.
Nicole Gooch
Membre depuis le 20/09/2017
207 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - Réponse
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 31
Total : 2,379
