Aller au contenu principal
Samsung Galaxy J3 Luna Pro Headphone jack Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Motherboard Change: étape 1, image 1 de 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 2, image 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 2, image 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 2, image 3 de 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 3, image 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 3, image 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 3, image 3 de 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 4, image 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 4, image 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 4, image 3 de 3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 5, image 1 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 5, image 2 de 3 Samsung Galaxy J3 Luna Pro Headphone jack Replacement: étape 5, image 3 de 3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: étape 6, image 1 de 2 Samsung Galaxy J3 Luna Pro Headphone jack Replacement, Headphone jack: étape 6, image 2 de 2
    • Use the flat end of a spudger to pry up the headphone jack cable connector from its socket on the motherboard.
Brandon Mendoza
Membre depuis le 01/29/18
646 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S5-G5, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 14
Total : 1,201
