Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
Remove single screw from back of device. This is the only screw that must be removed to take off this piece.
