Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy J7 Midframe Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy J7 Midframe Replacement, Back Cover: étape 1, image 1 de 2 Samsung Galaxy J7 Midframe Replacement, Back Cover: étape 1, image 2 de 2
    • Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
    • Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
    • Pry open the cover: Carefully work around the edges to remove the back cover completely
    • If the cover is stuck do not force it open use a plastic opening tool to avoid scratching the case.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy J7 Midframe Replacement, Battery: étape 2, image 1 de 2 Samsung Galaxy J7 Midframe Replacement, Battery: étape 2, image 2 de 2
    • Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
    • Remove Battery: Gently pop out the edge and carefully pull out the battery.
    • Tip: Ensure the battery is disconnected from the motherboard before removing it.
    Demander à FixBot
  3. Samsung Galaxy J7 Midframe Replacement, Midframe: étape 3, image 1 de 1
    • Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
    Demander à FixBot
  4. Samsung Galaxy J7 Midframe Replacement: étape 4, image 1 de 3 Samsung Galaxy J7 Midframe Replacement: étape 4, image 2 de 3 Samsung Galaxy J7 Midframe Replacement: étape 4, image 3 de 3
    • Lift up the back of the device with the iFixit opening tool and disconnect it from the front.
    • If the back panel is difficult to remove, gently heat the edges using a hair dryer or heat gun to soften the adhesive.
    Demander à FixBot
2 autres ont terminé cette réparation.
Timothy Grubb
Membre depuis le 02/05/19
744 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 51
Total : 1,822
