Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy J7 V Rear Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy J7 V Rear Camera Replacement, Screen: étape 1, image 1 de 1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy J7 V Rear Camera Replacement: étape 2, image 1 de 1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
    Demander à FixBot
  3. Samsung Galaxy J7 V Rear Camera Replacement: étape 3, image 1 de 1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
    Demander à FixBot
  4. Samsung Galaxy J7 V Rear Camera Replacement, Home button: étape 4, image 1 de 1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
    Demander à FixBot
  5. Samsung Galaxy J7 V Rear Camera Replacement: étape 5, image 1 de 1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
    Demander à FixBot
  6. Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: étape 6, image 1 de 2 Samsung Galaxy J7 V Rear Camera Replacement, Remove the backing: étape 6, image 2 de 2
    • Use the indent on the right side of the phone to lift up the backing
    • With the phone faced downwards, remove the backing of the case, lifting up from the right side
    Demander à FixBot
  7. Samsung Galaxy J7 V Rear Camera Replacement, Remove the battery: étape 7, image 1 de 1
    • Carefully remove the battery by lifting the bottom side, and then fully remove the battery
    Demander à FixBot
  8. Samsung Galaxy J7 V Rear Camera Replacement, Motherboard: étape 8, image 1 de 1
    • Remove fourteen screws from the midframe using a Phillips #00 screwdriver.
    Demander à FixBot
  9. Samsung Galaxy J7 V Rear Camera Replacement: étape 9, image 1 de 1
    • Flip the phone to the back side where the battery was removed.
    • Apply pressure with your hands to pop the midframe off.
    Demander à FixBot
  10. Samsung Galaxy J7 V Rear Camera Replacement: étape 10, image 1 de 2 Samsung Galaxy J7 V Rear Camera Replacement: étape 10, image 2 de 2
    • Flip the phone back over.
    • Remove the single black screw from the motherboard using a Phillips #00 screwdriver.
    • Place a few iFixit opening picks beneath the motherboard.
    • Spread the opening picks evenly around the motherboard to ensure it does not bend as you remove it.
    • Lift the motherboard using the iFixit opening picks.
    Demander à FixBot
  11. Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: étape 11, image 1 de 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: étape 11, image 2 de 3 Samsung Galaxy J7 V Rear Camera Replacement, Rear Camera: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the tweezers to detach the tab securing the rear camera.
    • Use your fingers to pull the camera away from the motherboard.
    Demander à FixBot
2 autres ont terminé cette réparation.
Aidan Clark
Membre depuis le 02/08/22
136 Réputation
1 tutoriel rédigé
Équipe
1 commentaire de tutoriel
goood
شكرا كتير لقد استفت من الموقع جدا واتمنى ان اواصل معرفه واطلاع على كل جديد
ageedaa11 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 32
Total : 991
